low idle, bad mpg, lacking power -please help!
Old Jun 7, 2011 | 10:21 PM
sabresfan's Avatar
Car: Looking for a new thirdgen
Engine: hopefully a 5.7L 350
My car has been idling quite low and hasn't been running great at all recently. MPG sucks (around 10 mpg) and it isn't giving me the power and giddy up it should have. When i am coasting along and i slam on the gas it takes a few seconds to really pick up and even then there isnt much power there. When i hit the gas at a dead stop there's not a whole lot of power at all, i cant even make the tires squeel. burnouts are non existent and i know with these v8's with rear wheel drive i should be able to spin the tires all day. I'm not one to drive like a maniac but im paying for all this power at the pump and im not getting what i am paying for.
On top of everything im new to cars so i have no idea where to start
Old Jun 8, 2011 | 12:07 AM
camaroinoh's Avatar
Car: 84 z28
Engine: 305 for now, lil more then stock
Transmission: 700r4 for now
Re: low idle, bad mpg, lacking power -please help!
Might be time for a good tune up plugs wire rotor cap
Old Jun 8, 2011 | 02:15 AM
383firebirdokc's Avatar
Car: 84 trans am 383 stroker
Engine: 5.7 383 stroker
Transmission: PRO BUILT 700r4 tranny
Axle/Gears: 3.73 rear disc posi
I just had the same problem, found out there was some problems from my wiring harness might wanna check ecm wiring harness could be spark plugs as well
Old Jun 8, 2011 | 08:28 AM
sabresfan's Avatar
thanks for the input so far. where would the ecm be on a carbed 86 iroc and how would i be able to test it? and any links to pics of it would be great
Old Jun 8, 2011 | 01:14 PM
camaroinoh's Avatar
Car: 84 z28
If it still there under dash on pass side
Old Jun 8, 2011 | 04:54 PM
I know its located battery side closer to the passenger engine bay wall I would just start looking for wires that look fried or ever frayed.
Old Jun 8, 2011 | 08:06 PM
sabresfan's Avatar
my wiring all over needs help
theshackle
Sep 17, 2020 08:26 AM
mdtoren
Aug 23, 2015 12:52 PM
InfinityShade
Aug 22, 2015 08:00 PM
mdtoren
Aug 16, 2015 05:45 PM
perZ
Aug 15, 2015 01:17 PM
