how many ohms should my fuel pmp have?
Old Jun 8, 2011 | 08:08 AM
foxmartin1's Avatar
Car: 1989 firebird formula
Engine: 5.0L V8
If I'm doing it right which I'm probably not. I'm getting around 60
Old Jun 8, 2011 | 07:53 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: how many ohms should my fuel pmp have?
why are you ohming out your fuel pump? do you mean your sending unit for the gauge?
Old Jun 8, 2011 | 09:38 PM
foxmartin1's Avatar
Engine: 5.0L V8
I was trying to figure out why every fuel pump I put in it never put out more than 15 psi. But I figured it out. All three fuel pumps I tried were for the non fuel injected model 305. I've got the right one coming in tomorrow
Old Jun 8, 2011 | 09:45 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
that would be the pump for the TBI engines, you apparently need the one for the TPI engines, much higher pressure
Old Jun 8, 2011 | 09:52 PM
foxmartin1's Avatar
Engine: 5.0L V8
Yeah I know. My car is sitting out back of VIP waiting for the right one to come in tomorrow. Once it does ill install it and work from there if the problem isn't fixed
Old Jun 8, 2011 | 10:12 PM
foxmartin1's Avatar
Engine: 5.0L V8
But this mistake did work in my favor. The tpi is about 30$ more expensive than tbi and they are just swapping it out for me so I save 30$
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
