Need help with cam suggestion
Old Jun 9, 2011 | 07:29 AM
galletti's Avatar
Car: 1988 IROC Convertible
Hi fella's! I need a suggestion as to what cam I need. It's kinda dark magic for me so here's my combo:
'88 IROC convertible TPI LB9
K&N filters with CAI
Ported and siamesed stock plenum
Edelbrock runners
Edelbrock base
Ported and polished stock heads with LS1 valves and springs
1-3/4 headers with y-pipe
3" high flow cat
3" Flowmaster cat back
I'll be doing a DIY prom for which I'll also need recommendations
So...what cam should I get. Thanks.
Old Jun 13, 2011 | 10:09 PM
galletti's Avatar
Re: Need help with cam suggestion
Bump. Anything?
Old Jun 13, 2011 | 10:28 PM
TNT_Z28's Avatar
Car: 1987 Camaro Z28
Engine: 355ci, XE262 , 650dp
Transmission: T-5, RAM clutch
Axle/Gears: 3.23 limited slip
Do you really want to cam a 305?
Around a 268 advertised intake duration is all the bigger a 305 should receive, if that.
Old Jun 13, 2011 | 10:50 PM
Guest
Guest
Posts: n/a
Based on when I had my '86 IROC-Z, and that you plan on a custom tune, I'd look at something like a 218/224-110, 495/502 for a lot of power.
Old Jun 14, 2011 | 12:21 AM
galletti's Avatar
I definitely want to stick with the 305. Thanks for the comments guys.
junkcltr
Aug 2, 2019 11:12 PM
transamgta87
Sep 1, 2015 07:07 PM
camaro71633
Sep 1, 2015 10:24 AM
InfinityShade
Aug 22, 2015 08:00 PM
drathaar907
Aug 6, 2015 04:20 PM
