checking my timing...procedure question?
Old Jun 12, 2011 | 02:33 PM
razman340's Avatar
Car: 1985 Z28
Engine: 305ci 4barrel
Transmission: 5-speed
85' Z28, 305ci carb....the tune up sticker under the hood recommends TDC setting at idle, but also says to unplug a wire before checking the timing. my Haynes manual says Don't unplug wires....
does anyone know which is correct, and are we talking about the four wires coming out of distributor, or another wire? thanks! Rick
Old Jun 12, 2011 | 02:42 PM
picklefuller's Avatar
Car: 1990 rs
Engine: 3.1
Re: checking my timing...procedure question?
I ALWAYS go buy whats under the hood. Haynes and chiltons have both been wrong at times for me. especially in ignition and electrical stuff.
Old Jul 20, 2011 | 08:16 PM
19camaro83's Avatar
Car: 1983 camaro sport coupe
Engine: 2.8l v6 - stock motor
Transmission: NWC t-5
Axle/Gears: whatever came stock (?)
I realize this thread has been ended for a little while now, but I have a question pertaining to this and I didn't want to start a new thread if I didn't have to. I am going to be replacing my distributor cap and rotor, along with wires and plugs tomorrow, and I was wondering what I needed to unplug before I set my timing? My car is an 83 2.8 carb. v6. What do I need to unplug, and where is it located? My sticker under the hood is missing, so I can't get the info I need there, and searching is getting me nowhere.
Old Jul 20, 2011 | 09:08 PM
razman340's Avatar
Car: 1985 Z28
on my 85' i found the wires coming out of the back of the distributor, and followed them back by the firewall, and there was a plug. this needed to be unplugged while i was setting the timing. then once timing was set, i plugged it back in...runs GREAT now...Rick
Old Jul 20, 2011 | 09:16 PM
19camaro83's Avatar
Thank you! Hopefully my 2.8 is the same as a 5.0
I will check it out tomorrow.
Old Jul 21, 2011 | 07:16 AM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
http://carphotos.cardomain.com/ride_...0360_large.jpg
this is for a 5.0, IDK if yours would be the same.
Red iroc-z 305
Sep 30, 2015 05:22 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
