oil builup in heads, gunk, and one head full of oil ??
Old Jun 12, 2011 | 05:52 PM
Motopsyco's Avatar
Car: 89 firebird, 03 Avalanche z71
Engine: 5.0 stock (for now)
Transmission: 700R4 auto
Axle/Gears: stock 2.73 for now
Ok heres the deal, since my bird, an 89 305 tbi has been sitting and going to start driving it, I figured I'd replace the valve seals since its smoking alot now and wasnt much before it sat, well I took off the drivers side valve cover and noticed and extremely large amount od crud buildup in the valve cover and the head, so much I couldnt hardly tell were any bolts were. So I decided to go ahead and take the heads off get new gaskets and probably throw in an lt1 cam while I'm at it, things went pretty smoothly for a neglected 22 year old car until I got to the passengers side and took the valve cover off and oil spilled out everywere, the whole head and valves were submerged in oil. My question is: Were are the oil passages in the head and do you think they are just plugged with crud, or maybe a bigger issue, or would it be normal to have a head full of oil, the car isnt sitting completely level, but I havent ran it in about 4 days so it should have drained back to the pan right? Any ideas here are greatly appreciated, and hopefully I get some ideas before it gets dark out.
--Thanx, Brian
theurge
Aug 21, 2015 12:46 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
