Random 1990 Formula questions
Old Jun 14, 2011 | 01:59 PM
formula90fan's Avatar
My hood wont fully pop open when I pull the latch, I have to jiggle the hood a little, what do I adjust to fix this. Pictures appreciated.
My 1990 Pontiac Firebird 5.0 T.B.I has a roughish idle. It usually wobbles from 600-800 or so but occasionally drops to like 200-300 for a second. It does this at stops and will sometimes die, just like I turned the key off. It starts right back up. I have heard replacing the MAP sensor and TPS sensor might fix this(From other threads in this forum). I also plan on replacing spark plugs, distributor cap and rotor, and wires, along with air filter. Any other suggestions?
Does this year of my car have a MAF sensor?
Also can someone send me some good clear pictures of the engine bay of their 1990 Pontiac Firebird 5.0 T.B.I?
Thanks for anyones help, I really like these forums.
Old Jun 14, 2011 | 03:11 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Re: Random 1990 Formula questions
Check the IAC motor on the throttle body,cleaning it should help. There is no MAF on a '90 model or TBI car.
Old Jun 14, 2011 | 09:27 PM
Thanks, I will try that tomorrow. Ill post my results tomorrow as well
Frozer!!!
Jan 19, 2024 04:55 PM
Jorlain
Aug 24, 2022 05:11 PM
okfoz
Mar 9, 2017 02:35 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
