fuel gauge
Old Jun 14, 2011 | 09:15 PM
shoemaker89's Avatar
Car: 89 camaro
Engine: 305tbi
Transmission: 5 speed manul
fuel gauge
i have an 1989 305 tbi 5 speed camaro but the fuel gauge stays on full dues that mean the sending unit needs to be changed for just a bad gauge
Old Jun 17, 2011 | 09:53 PM
redcamaro1988's Avatar
Car: 1988 Chevy Camaro
Engine: 305 TBI
Re: fuel gauge
To check the sending unit without dropping the tank since you have to drop the rear axle. Jack the rear of the car you should see a wiring harness with three wires (unsure of the colors) unplug it. Turn the car to the on position and see if it goes to empty. If it dont try using a jumper wire on the harness and check that way. I found out my sending unit was bad because of the jumper wire then pulled the unit out of the tank and noticed that whoever changed the fuel pump broke the float arm off. I hope that helps
Old Jun 18, 2011 | 01:34 AM
Car: 89 camaro
Engine: 305tbi
Re: fuel gauge
ive tryed that it always stays on full
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
R3500
Aug 17, 2015 12:16 PM
