need help!! 86 iroc runs like crap until motor warms up..
Old Jun 15, 2011 | 08:42 PM
ray jr's Avatar
i bought a 86 305 tpi iroc with 40k on it ...it sat for a long time so i replaced fuel pump,fuel filter,plugs,wires,o2 sensor,cap and rotor ... when i start it up cold it runs like crap ..wont idle,breaks up etc.. when it warms up it runs great ... it has no codes .. any idea's what i should check next ?? im going to put new bosch injectors in next and try that ... maybe iac motor ???
Old Jun 15, 2011 | 09:53 PM
cubby-5056's Avatar
Car: 1991 Z28
Engine: 350 LT1
Transmission: T 56 (converted from 700r4)
Axle/Gears: 4.10 from a 2000 TA
Re: need help!! 86 iroc runs like crap until motor warms up..
Probably the IAC or the CTS
Old Sep 11, 2011 | 05:35 PM
jb1's Avatar
jb1
anyone else have a clue as to what could be wrong with this?
Old Sep 11, 2011 | 09:32 PM
ray jr's Avatar
i cleaned the iac motor and it helped alot ...i also put new gas in it with some fuel injector cleaner so that might of helped to ...i think the gas was old cause after i ran the new gas for awhile it ran alot better ..between the 2 things it made a world of difference ..
Old Sep 12, 2011 | 01:49 PM
jb1's Avatar
jb1
Thanks, did you ever replace the injectors?
Old Sep 12, 2011 | 08:00 PM
ray jr's Avatar
if i kept the car the 2 things i wanted to do was change the iac motor and new injectors cause i heard the old injectors from the eighties were garbage ..i didnt put new injectors in ...i have them though ...if you want them there yours ..ill send them out this week ..
Old Sep 13, 2011 | 05:07 AM
jb1's Avatar
jb1
Those are the exact 2 things I plan on doing first. If you could send those to me I would greatly appreciate it.
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Elliswon
Aug 10, 2015 12:33 PM
