Is this a bad symptom..
Old Jun 16, 2011 | 09:05 PM
Electro_X's Avatar
Car: 84 T/A Recaro
Engine: L69 H.o
hello
i just want to ask if this is something to worry about. If i move that purge valve As shown in picture (Wiggle It) from side to side my engine wants to stall or it revs up the RPMs is this a bad purge valve?
thank you
Old Jun 17, 2011 | 08:06 PM
Electro_X's Avatar
Car: 84 T/A Recaro
Engine: L69 H.o
Re: Is this a bad symptom..
Anything on this? what will happen if i take it out? also to add my car runs rough.
Old Jun 17, 2011 | 08:11 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Can't see it well in the photo - I assume it's the purge valve for the fuel? If so, might have a leak, thus causing a vacuum leak, thus the rough engine running when it's "wiggled".
Old Jun 17, 2011 | 08:33 PM
Electro_X's Avatar
Car: 84 T/A Recaro
Engine: L69 H.o
thanks for answer
yes it is purge valve not really sure what it does but it has 4 tubes connected to it and yeah when wiggled engine runs low,high ,stall . i will put in new one and see what it will do.
thanks
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
L98GTA87
Oct 19, 2015 10:43 PM
dimented24x7
Sep 17, 2015 06:58 AM
gta892000
Sep 16, 2015 12:40 AM
