Disabling fuel/ignition on 305 TBI?
Old Jun 17, 2011 | 06:24 PM
Flightoficarus's Avatar
Hey all,
So after throwing more parts at it than needed, it's come to doing a compression test on my 305 to find out if valve seals might fix it, or if it's in need of rebuilding/replacement. A spark plug analysis confirmed that it's burning some oil, but I'm not sure how bad it's looking yet.
I don't think I need to go into how overly general and vague Haynes manuals can get, so I need to know what the PROPER way of disabling the fuel and ignition are so I can do the test. I've read of one way to disable fuel that says to disconnect the harness from the pump itself...surely, there must be an easier way? Or is getting to the pump itself the only way?
Also, I've read to "disconnect the wiring harness from the ignition coil", but there aren't any pictures of this, or even info on where relays for things are located. Some more specific instructions, or even pics would be tremendously more helpful than this crappy book!
Thanks!
Old Jun 17, 2011 | 07:51 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Disabling fuel/ignition on 305 TBI?
You can just remove the coil wire from the coil or the distributor cap - no coil means no spark means no fire.
Old Jun 17, 2011 | 09:29 PM
redcamaro1988's Avatar
Car: 1988 Chevy Camaro
Engine: 305 TBI
I would unplug the two harnesses from the two tbi injectors and pull the coild wire
Old Jun 19, 2011 | 02:05 PM
Unplugging the harnesses to the injectors sounds like it would stop fuel from getting to the motor, but wont the fuel pump still try to send fuel, and build up pressure in the fuel system?
Old Jun 19, 2011 | 04:23 PM
Engine: 305 TBI
I just unplugged my TBI Injectors when I was trying to get it in time. You can always pull the fuse for the fuel pump
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
