How to remove this?.................
Old Jun 18, 2011 | 09:42 PM
R/T-Z28's Avatar
I am trying to repair the contacts that actuate the blinkers but this thing is in the way. Do I have to use a pulley or is there another way of getting it off?
Any help would be greatly appreciated.
Old Jun 18, 2011 | 10:04 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Re: How to remove this?.................
Yes you will, just try and have a system where everything goes back.
You can get a kit at any auto store, for less then $10 bucks. Good luck, I hope you have a manual.
Old Jun 18, 2011 | 10:05 PM
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
There's a thread on here somewhere on how to take all that apart.
Old Jun 18, 2011 | 10:14 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
there is a good write up around here that has good pictures, try searching ign cyclinder or tightening steering column. From what I remmeber from mine, you need to depress that pc and remove the snap ring. I used a pc of flat stock with a hole drilled in it, the nut you removed for the steering wheel and 2 sockets between the flat stock and that pc. Then use some small flat blade screw drivers/picks to get the ring off. Careful when loosening the nut as there is a spring behind that plate. Its not hard if you find the write up and keep track of the parts.
Old Jun 18, 2011 | 10:23 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
try this
https://www.thirdgen.org/forums/inte...eel-grant.html
https://www.thirdgen.org/forums/tech...nal-wiper.html
Old Jun 18, 2011 | 10:26 PM
bm87ta's Avatar
Car: 87 TA
Engine: 305 tpi
Transmission: auto
maybe this too before you tear everything apart
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
