305 tpi need help
Old Jun 20, 2011 | 10:06 AM
bad_to_the_bone's Avatar
Car: 89 iroc-z
Engine: 427 bbc
Transmission: borg warner t-5
Axle/Gears: 3:23 posi
305 tpi need help
hey guys i just picked up an 86 iroc-z t-top auto trans with a 305 tpi ...
the car did not like starting at first hot or cold made no difference so i canged the ect (engine coolant temp) sensor and now the car fires up every time no issues... but i have an issue the temp guage dont work and when the car is in a coast the idle fluctuates between 1250 and 1750 rpm wondering what could be the cause and is there a way to check see if the electric cooling fan works with out jumping it at the motor itself i would like to see if the whole system works?
Old Jun 21, 2011 | 06:25 AM
Car: 89 iroc-z
Engine: 427 bbc
Re: 305 tpi need help
so tonight im changing the temp sender for the guage hope this makes the guage work and im going to change the temp sender for the rad fans at same time and install new air filters hope this makes thing little better but when i get a chance to drive it to work im changing the fuel filter and go from there lol but not sure why the engine revs up and down when coasting or slowing down if i shift manually it does not have the issue but its not a fix for the issue
Old Jun 22, 2011 | 06:48 AM
Car: 89 iroc-z
Engine: 427 bbc
well after changing the temp sensor for the guage it still dont worrk and i never took it for a drive but the rad fan works great and with air filter and fuel filter change it did not changet the reving up and down when coasting to a stop in drive
Old Jul 10, 2011 | 03:53 PM
TAG305's Avatar
Car: 87 firebird formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 373:1
try changing the iac that has alot to do with your idle
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
