1992 305 tbi not starting no fuel
Old Jun 22, 2011 | 11:10 AM
al1270's Avatar
Car: 1989 Iroc
Engine: 383
Axle/Gears: 4th gen posi 3.73
I got this car for my wife over the winter. The p.o. said it was sitting for a year but was started once in a while. It ran when we parked it now the engine turns but won't start. I replaced the fuel filter and cleaned the injectors but dosent seem to be getting fuel. If you pour some gas in the tbi t starts and runs untill the fuel is gone. I have checked the fuses and there is a relay on the firewall drivers clicking when you turn the key on. I am not hearing the fuel pump come on (should I?) I can hear the fuel pump on my tpi iroc come on. Any ideas or is the fuel pump dead? The car is for sale but everyone is asking why it wont start so I would like to get it running maybe it will sell.
Old Jun 22, 2011 | 02:41 PM
Napster134's Avatar
Car: 1991 Pontiac Firebird
Engine: 355 TBI
Transmission: 7004R
Axle/Gears: 3.27/42 ?
Re: 1992 305 tbi not starting no fuel
Yep, your fuel pump should be priming and you should be able to hear it if you listen carefully. Now if you dont hear it, go over to your cars battery and right in front of your battery is a tiny lil black box that should be mounted to the fender.
Pop open the cap to that lil box and there will be a (fuel pump) fuse. Make sure its not popped.
Old Jul 1, 2011 | 09:01 AM
al1270's Avatar
Car: 1989 Iroc
Engine: 383
I checked next to the battery and there is a fuse. It's good. There are are 2 relays against the firewall on the drivers side. One of those clicks when I turn the key. Should both of them be clicking when I turn the key? I don't really want to drop the tank unless I have to.
Old Jul 1, 2011 | 09:38 AM
conlinj's Avatar
only one should click and thats a good sign, sounds like your fuel pump went. If the relay wasn't clicking I would say start there. I forget which terminals to use but if you search you can find which termials to jump to check the fuel pump. Just pop the line off where it goes into the tbi and put it into a bucket. That should give you an idea if the pump is working or not.
Old Jul 1, 2011 | 10:37 AM
al1270's Avatar
Car: 1989 Iroc
Engine: 383
I did a search for the fuel pump wires. I ran a jumper from the large orange wire to the tan/white wire and nothing happened. The orange wire is getting 12.88 volts. Before I drop the tank on this thing. Are there any more tests to do or is jumping the orange wire to the tan/white wire it to test the fuel pump? I did not pull the fuel line loose I just listened for the fuel pump to come on.
Old Jul 1, 2011 | 02:48 PM
conlinj's Avatar
You should of heard the relay click when you jumped the wires too. Did it?
Old Jul 1, 2011 | 07:20 PM
al1270's Avatar
Car: 1989 Iroc
Engine: 383
I had the relay unplugged to jump from the orange wire(power feed) to the tan/white wire(main power to the fuel pump).
Old Jul 2, 2011 | 11:33 AM
conlinj's Avatar
Sorry thought you were talking about the ALDL terminal under the dash. Looks like your replacing the fuel pump...
Old Jul 2, 2011 | 01:50 PM
al1270's Avatar
Car: 1989 Iroc
Engine: 383
I might replace it. I really want to work on my iroc project. I lowered the price on the 92 rs.
pimp2303
Jul 27, 2017 02:03 PM
Jae992
Aug 27, 2015 09:07 AM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
