need some help with too much pressure
Old Jun 22, 2011 | 09:31 PM
NeoTath's Avatar
Car: 1987 Firebird Formula 350
Transmission: 700-R4
i need some help because my old fuel filter broke because of way too much pressure. i put a new on on it, i am wondering if it is going to break too. the people that i bought it from switched it from fuel injected to carb. they have a long *** return fuel line running all the way around the car. how does this create soo much pressure, and how could i stop it?
Old Jun 23, 2011 | 08:59 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: need some help with too much pressure
Is it a RETURN-STYLE regulator? You need a return-style regulator like the Mallory 4309, and then the correct fuel line sizes/barbs. If they tried squeezing a 3/8 hose barb into the 5/16th hose, then they cut the hose inside, and created a restriction thus increasing pressure.
Old Jun 23, 2011 | 09:03 PM
NeoTath's Avatar
dont have a regulator.
Old Jun 23, 2011 | 10:44 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
If you have an EFI fuel pump, it needs a bypass style regulator. Youll need a 3-way with a carb. Its probably dead-heading at this point.
db057
Jan 10, 2020 08:55 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Stryker412
Sep 20, 2015 06:59 PM
CatmanFS
Sep 19, 2015 09:00 AM
TBRays98
Sep 6, 2015 05:05 PM
