timing 180ish off help please
Old Jun 24, 2011 | 12:14 AM
affliction1's Avatar
Car: 89 chevy camaro rs
car is firing on exhaust stroke,can i get back to compression stroke by gett it at tdc on exhaust stroke,then pull dist. out spin crank full 360 untill timing mark lines up again(will it be on tdc compression stroke?),and drop dist in ,then gett timing tuned in.also whats the factory timing for a 91 305
Old Jun 24, 2011 | 12:17 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: timing 180ish off help please
Yes, that will get the distributor in position.
Old Jun 24, 2011 | 12:23 AM
thank the lord should i line it up at 0 degrees to startout with?
Old Jun 24, 2011 | 12:26 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not sure what the timing spec is, I'd guess about 6 to 8 degrees.
Old Jun 24, 2011 | 12:29 AM
thanks brother
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
