car dies after new iac
Old Jun 24, 2011 | 09:21 PM
pjp209's Avatar
Car: Gone
i did everything from cleaning tb too tps adjustment and idle screw adjustment. now my car starts but wont stay on. any ideas what can this be
Old Jun 24, 2011 | 11:23 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: car dies after new iac
Any codes?
Old Jun 25, 2011 | 01:57 AM
pjp209's Avatar
Car: Gone
Originally Posted by Base91
Any codes?
no but ill scan it anyway .
Old Jun 25, 2011 | 06:28 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
ECM needs to learn the new IAC motor. Try it with the A/C on and off, and alternate between park and drive.
Old Jun 25, 2011 | 10:40 AM
pjp209's Avatar
Car: Gone
no ac
Old Jun 25, 2011 | 07:02 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Did you follow the instructions for setting the iac pintle before installing it? If not try it again. Everything plugged back in right? If it fires let it idle for a while.
Old Jun 25, 2011 | 08:19 PM
pjp209's Avatar
Car: Gone
i did follow the instructions. plugged everything in rite. it will start then die if i dont hold the gas pedal down a lil. i also set idle but it wont stay on if i put it at 400rpm. im thinking that lazy guy at auto zone didn't give me the iac i needed so ima put old one on and take new one back.
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
