which fuel pump is best?
Old Jun 26, 2011 | 04:22 PM
Broone115's Avatar
who makes an excellent fuel pump that will last for ever and flow really well? Is Mallory or Carter good makes? what about Holleys fuel pump or BBK? and what LPH should I get for a stock 5.7 350 TPI?
thanks in advance
Old Jun 26, 2011 | 07:21 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: which fuel pump is best?
No guarantees on anyone's brand of pump. Alot of folks like the Walbro's. I installed a AC/Delco pump from CarQuest 5 years ago and no problems here {yet}. I figure the GM OEM part lasted 15 years with no issues, so another one should last another 15 years - but only time will tell the tale.
Old Jul 31, 2011 | 01:06 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
from rockauto.com
$40-$100
PERFORMANCE ELECTRIC Part # P240KC More Info REPAIR KIT; Fuel Pump and Strainer Set For Models w/ M.F.I. & 1.45" Diameter Pump. Some applications may require the use of the original tank flange seal.
$36.79
AIRTEX Part # E3240 More Info {#E3904} In Tank Electric Fuel Pump
Wiring Harness replacement recommended
$46.79
BOSCH Part # 69222 More Info Electric Fuel Pump Kit; (wiring harness, adapters, o-rings, clamps, sleeves)
$57.89
DELPHI Part # FE0039 More Info {#FE003911B1}
$62.79
CARTER Part # P74006 More Info Electric In Tank
Includes Wiring Harness
$65.79
ACDELCO Part # EP240 More Info {#25116162} DOES NOT INCL STRAINER.
PUMP,FUEL (ELEC)
$68.79
CARTER Part # P60469 More Info In Tank Pump & Strainer Set
$77.79
DENSO Part # 9515006 More Info
OE Replacement Fuel Pump
* Non-stock item--shipping delayed up to 2 business days
$91.79
Old Jul 31, 2011 | 01:11 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I love everything said about the Bosche pump except the near quiet running
nice to hear it prime and know its working.
http://www.rockauto.com/catalog/moreinfo.php?pk=977011
"Bosch state-of-the-art turbine fuel pumps offer many advantages when compared to older roller-cell and inner-gear pump designs. Not only do these pumps offer near silent operation and improved drivability, the core components of this turbine design significantly reduce wear and deliver a longer service life. Illustrated step-by-step instructions are included with all Bosch Turbine Fuel Pumps for safe and easy installation.
Bosch Fuel Pump Features
Superior turbine pump design virtually eliminates fuel pulsation. Provides better drivability, reduced noise, and longer life
Bosch impeller ring provides smooth fuel flow and reliable performance
Precision, spin-balanced and polymer-encased armature reduces noise and vibration
Premium carbon brushes provide a longer and more reliable service life
Non-return valve maintains system pressure and reduces hot start problems
Noise suppression coil virtually eliminates radio frequency interference "
Old Jul 31, 2011 | 11:09 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
no other thoughts or comments on other brands?
Old Jul 31, 2011 | 05:27 PM
Car: 1992 RS
Engine: Carbed 350
I've always read here alot of folks complaining about the Airtex - I believe that's the standard el-cheapo pump from advance/autozone.
Old Aug 1, 2011 | 05:47 AM
z28romance's Avatar
Car: 87 z28 stock
Engine: 305 tpi
i have been selling auto parts for years. ive been selling delco for the last 5 as a wholesaler to shops. i discontinued airtex as almost every one i sold came back defective. right now i sell delco and denso pumps, the only ones i would recommend aside from those are delphi and bosch. however, bosch's quality has been slipping in recent years and delphi is still in bankruptcy.
Old Aug 1, 2011 | 07:23 AM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
alot of people like walbro in LS/LT swaps. havent heard mopre than a few bad experiences with them
Old Aug 1, 2011 | 08:11 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
best Aeromotive external
Old Aug 1, 2011 | 03:26 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
big fan of ACDelco, Walbro, and Bosch pumps. All well made, very few issues. I've personally run acd and walbro in my own vehicles. Since these cars are such a bear to do a pump swap on, I'm more than happy to pay a few extra dollars to save doing the job again any time soon.
Old Aug 2, 2011 | 12:03 PM
gmstrong's Avatar
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
+1 for walbro
Old Aug 3, 2011 | 04:11 PM
92formula12's Avatar
Car: 1992 Firebird Formula
Axle/Gears: Posi
Do it right the first time and go with delco or walboro cause we all know its a pain dropping that tank.
Old Aug 3, 2011 | 04:21 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Agree with whats been said so far. Lest not forget my hometown pump heros
http://fuelab.com/
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
