fuel pump howling and car wont start..guessing its not getting fuel?
Old Jun 27, 2011 | 07:21 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
as the title says...when it primes, it howls and then when i start it, it trys to start but it seems to not be getting fuel..i noticed that when i try it a couple times then open the fuel filler neck, a lot of pressure is released everytime...is there like a vent valve or something?
please help..car is sitting on the side of the road..\
Old Jun 27, 2011 | 08:01 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: fuel pump howling and car wont start..guessing its not getting fuel?
What's the fuel pressure reading while cranking?
Old Jun 27, 2011 | 08:26 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
its working great again now...
my grandpa said it was probably vapor lock?
so i getta vented gas cap i guess..
it was really hot today to so that added to it.
Old Jun 27, 2011 | 08:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
How long since a fuel filter change? IMO, "vapor lock" is an explaination (ie excuse) when nothing else comes to mind - I personally would keep hunting for an issue.
Old Jun 27, 2011 | 10:45 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
literally JUST changed the fuel filter..
Old Jun 28, 2011 | 01:48 PM
koolz's Avatar
Hey man I'm actually having this same issue with my car as I text you about this ,but to get my 92 camero Z-28 with a 5.7 eng starting again. We changed out the fuel Pump Sending unit and for my car it wasn't cheap it hit me for about $245.00 well man short of changing out your Fuel Pump I hope this get's you back on the road.Peace
Old Jun 28, 2011 | 04:19 PM
WhiteRS91's Avatar
Car: '91 RS Camaro
Engine: 5.7L Fuel Injected V8 (B4C package)
Transmission: 4-speed auto
Axle/Gears: 3:23
Koolz, I did the same thing with my 91 Camaro RS, with the Z-28 5.7eng. Seemed fine after the change, but now its starting to do the same thing.
If i let it set for a little bit, it starts up fine and runs fine, but as it heats up I acts like fuel isn't getting fed.
I'm gonna try what 'camaronewbie' suggested with the fuel filter change and hope to god that it works.
Old Jun 28, 2011 | 04:23 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
I had an ignition control module start causing an issue like this before.
Old Jun 28, 2011 | 06:22 PM
jhp73's Avatar
Car: 1987 iroc Z-28 5.7 TPI
Engine: 5.7 TPI
ehh my 87 iroc camaro started doing this and i ignored it then the fuel pump went out in the middle of a 1200 mi trip. Take it and get your fuel pressure tested you don't want to get stranded. Take Care
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
