Low oil pressure, burning oil
Old Jun 30, 2011 | 06:40 PM
C_Sander's Avatar
Car: 91 Camaro RS
Engine: Carbureted 305
Oil pressure problem:
When idling, oil pressure drops to the red line. Under acceleration, it jumps up to average, but at low speeds, there is a clattering noise once I start accelerating. The noise usually stops once the car hits about 30KM. What really worries me however, is that my engine seems to burn an excessive amount of oil. Every few months I have to fill it with oil. It isn’t leaking, because I don’t see any oil on my driveway, but it is usually completely empty after three months or so.
91 RS 305 TBI 210xxxKM
I would greatly appreciate any suggestions you have to offer, thanks alot!!
Old Jun 30, 2011 | 07:43 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Low oil pressure, burning oil
1) if it's completely empty after 3 months, you need to start checking it every week ... never let it get empty!
2) You can tell burning oil - makes blue smoke. Making any blue smoke?
3) get under the car and find the leak - might only leak when running under load, and thus the "missing oil" is hitting the pavement when you drive, not when you are parked.
Old Jul 4, 2011 | 10:19 AM
C_Sander's Avatar
Car: 91 Camaro RS
I have never seen any blue smoke, but I just checked and the exhast is pretty much invisible. Took a look underneath, but don't see any oil leaks. What I'm most worried about is that the oil pressure is at 0psi when idle regardless of the oil level. Same thing with that clattering noise - doesn't matter if it's fill or empty.
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
