Valve timing for 350 TPI roller cam
Old Jul 3, 2011 | 11:07 AM
pontiacivan's Avatar
Does anyone have the valve timing events for the 350 TPI roller cam? ( the 202/206 .403/.415 115 LSA cam) I know it's super lazy to ask instead of doing it myself , but as old as these cams are I bet the numbers are out there (Fast357?). I'm pulling the peanut cam from my 305 TBI this weekend and either this cam or a Vortec roller is going back in with 1.6 rockers. I have the events for the Vortec cam and I'm curious to see if 10+ years of tech make it the better choice over the TPI roller. Thanks to all.
Old Jul 3, 2011 | 12:30 PM
Guest
Guest
Posts: n/a
Re: Valve timing for 350 TPI roller cam
The Vortec cam is the better choice, because it's earlier IC is a better match to your no-flowing intake ports. The Vortec cam will give up at a similar RPM to your heads.
The info you asked for is -14 36 37 -11
You'll lose low-end torque because of the late intake closing, and your top end will still be weak because of your swirl-port heads.
Old Jul 6, 2011 | 10:37 PM
Thanks, I did decide on the Vortec cam for timing reasons.
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
wruiz
Aug 13, 2015 09:07 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
