Roller conversion
Old Jul 3, 2011 | 01:26 PM
MrPhotographer0's Avatar
Car: 1984 Camaro Sports Coupe
Engine: 355 chev
Transmission: none at the time
Axle/Gears: stock 10bolt v6 gears
Roller conversion
Just a thought, throwing it out there.
I believe my block has the correct bosses for the spider and all to convert to roller.
Is this all i need (other than drill/tap) to put a roller cam in?
http://www.summitracing.com/parts/SUM-150121/
Old Jul 3, 2011 | 02:09 PM
Guest
Guest
Posts: n/a
Re: Roller conversion
It doesn't include the shorter pushrods you'll need, and the thrust plate may have the wrong bolt spacing.
Plus what's pictured can be had for 1/4 that price from most salvage yards.
Old Jul 3, 2011 | 11:04 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Yep. There is an early (87 to 89??) thrust plate and the later one.
I have those parts + new lifters in box if you're interested; hadn't put them in classifieds yet.
Old Jul 3, 2011 | 11:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The block has to be milled for the dogbones too.
Old Jul 4, 2011 | 03:03 PM
Engine: 355 chev
ah. okay.
well, it was just a thought. I'm really just throwing my current motor togeather, and later down the road, i'll just start fresh with a roller block.
Linson
Oct 24, 2025 02:00 PM
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
