Car won't run right. Suggestions?
Old Jul 6, 2011 | 09:35 AM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
When I accelerate slowly my car feels like it is missing. It shakes as it accelerates, and runs like crap. If I step on it I do not notice it. It idles fine. I have recently replaced the spark plugs, wires, distributor cap, fuel pump and fuel injectors. Any idea what could be causing this? I am stumped.
Old Jul 6, 2011 | 12:20 PM
91Z28Ripped's Avatar
Re: Car won't run right. Suggestions?
Have you checked your MAF sensor(you may not have this) or MAP sensor for proper operation. This info to ECM may be off.
Old Jul 6, 2011 | 12:30 PM
rdhanded2's Avatar
Top Answer: 1
I was thinking it could be the Throttle position sensor. I may start there. It is a 91 so it is speed density.
Old Jul 6, 2011 | 10:55 PM
rdhanded2's Avatar
Top Answer: 1
Checked TPS and Map sensor. Not either of those. I actually replaced them both just in case.
Old Jul 7, 2011 | 09:36 AM
rdhanded2's Avatar
Top Answer: 1
Ok, so it is still rough while accelerating, and when I come to a stop it wants to die. I am out of ideas. Anyone have suggestions?
Old Jul 7, 2011 | 09:56 AM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Vacuum leak
Old Jul 7, 2011 | 09:59 AM
rdhanded2's Avatar
Top Answer: 1
I am dumb, where all would I check?
Old Jul 7, 2011 | 10:06 AM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
All vacuum hoses that attach to the manifolld, plenum, map sensor, power brake booster, charcoal canister.....
Old Jul 7, 2011 | 10:28 AM
rdhanded2's Avatar
Top Answer: 1
I will check them tonight and go from there. Thanks
Old Jul 7, 2011 | 01:55 PM
rdhanded2's Avatar
Top Answer: 1
Replaced the fuel filter since I had one. Still the same
Old Jul 7, 2011 | 08:05 PM
rdhanded2's Avatar
Top Answer: 1
Well, I can not see or hear any vacuum leaks. I did find 2 wires that are not plugged into anything. Not sure where they go or what they are. The first is up by the break booster.
Attached Thumbnails Car won't run right.  Suggestions?-imag0292.jpg   Car won't run right.  Suggestions?-imag0293.jpg
Old Jul 7, 2011 | 08:06 PM
rdhanded2's Avatar
Top Answer: 1
The second is under the front of the car hanging by the driver side.
Attached Thumbnails Car won't run right.  Suggestions?-imag0290.jpg   Car won't run right.  Suggestions?-imag0291.jpg
Old Jul 11, 2011 | 01:33 PM
StephenS's Avatar
Car: 1991 Z28 Camaro Convertible
Engine: 1988 305 TPI
I saw that same cable unplugged in my 91, i've always wondered what it is or where it plugs into
Old Jul 11, 2011 | 02:32 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Second one looks like the wire for the temp sender for the temp gauge. Does yours work or is it stock? Since you don't seem to have a stock engine, anything you can tell us about the engine in there now would make it easier to help
Old Jul 11, 2011 | 04:24 PM
rdhanded2's Avatar
Top Answer: 1
Stock 305 in a GTA, not the one in my sig. Sorry. Was the ignition module that was bad.
Old Jul 11, 2011 | 05:01 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Cool, If it runs right now you're probably a happy guy!
Old Jul 11, 2011 | 07:05 PM
rdhanded2's Avatar
Top Answer: 1
So far so good... this week..... lol
specialized
Jun 18, 2022 09:26 AM
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
mizz0313
Aug 12, 2015 06:45 AM
