Odd noise in the vents
Old Jul 8, 2011 | 10:40 AM
jstanfi1's Avatar
Car: 1992 T/A Convertible
Engine: LB9 305 TPI
When braking, or sometimes when just driving, I get a strange, almost metallic sounding "swooshing" nose in dash, likely from the vents. It's definitely more noticeable on the passenger side. Does it whether the A/C is on or off, but only when the blower fan is on. Ideas?
Old Jul 8, 2011 | 10:52 AM
Elthesh's Avatar
Car: 1991 Pontiac Trans Am
Re: Odd noise in the vents
My first guess would be that either the fan bearings are going bad, or more likely, there are leaves or junk bouncing around in the fan cage. Just pull it out and look. Like 5 little screws hold it in. Check inside the box with a light too. Could be leaves or trash in there if you don't see anything in the cage.
Old Jul 8, 2011 | 11:09 AM
jstanfi1's Avatar
Engine: LB9 305 TPI
Cool, thanks. Sounds simple enough, so I'll check it out tonight. The metallic sound is throwing me off, but yeah, now that you say it bearings would make sense.
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
Fanatic1074
Oct 2, 2015 03:47 PM
sjorgens
Oct 1, 2015 07:54 PM
