help with the icm
Old Jul 9, 2011 | 02:53 PM
scarr001's Avatar
Car: 92 camaro rs anniversary edition
Engine: v8 5.0 Tbi
help with the icm
i need help in replacing the icm on my 92 5.7 v8 camaro? will one of u "rockstars" please help with instructions?
Old Jul 9, 2011 | 10:02 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: help with the icm
Not a rock star but:
Disconnect plugs from dist.
Remove dist cap and rotor. The icm is the banana-shaped black box under the rotor, held down by 2 screws.
Unplug the pickup coil from the end of the icm.
Undo the 2 screw, pull module. It might be stuck in pretty good with the remnants of the dielectric grease.
Put plently of dielectric grease on the bottom of the new module - probably supplied with the module. Bolt back in and reverse above.
Old Jul 9, 2011 | 11:37 PM
scarr001's Avatar
Engine: v8 5.0 Tbi
Treefiddy in a single moms eye, trying to get that car running for my 17 year old, u are a rockstar! Great info!
Old Jul 10, 2011 | 03:30 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Well, hope it helps! Assume this relates to the problem in your other thread - dying after 15 mins. Didn't the whole distributor get replaced last year? This would have included a new icm - I assume it was a NEW dizzy. Is the car still overheating, was that ever solved?
RedLeader289
May 28, 2019 01:47 PM
MM2Robinson
Oct 1, 2017 09:16 AM
djmarch
May 8, 2016 11:32 AM
RedLeader289
Sep 23, 2015 06:50 AM
Thornburg
Aug 30, 2015 08:05 AM
