choppy idle, lurching forward in drive, then goes away...
Old Jul 10, 2011 | 06:00 PM
nakota2k's Avatar
Car: 1989 Iroc-Z 350
On startup idles really choppy at or below 500 rpm, putting it in drive it lurches and jumps forward sporadically. If I rev it in park or continue to give it gas in drive something just catches and it goes back to normal idle and its fine until I have to start the car again. To me it sounds like a cylinder mis-fireing or not firing at all. What do you guys think?
89 Iroc-Z 350.
Old Jul 10, 2011 | 09:35 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
Re: choppy idle, lurching forward in drive, then goes away...
clean the idle motor and passages
Old Jul 10, 2011 | 09:44 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
Engine: 350 ATK Performance
Axle/Gears: Eaton 3.73
check your IAC
Old Jul 10, 2011 | 10:59 PM
nakota2k's Avatar
pulled out the IAC and the spring and metal pin inside were black with carbon. Put it back in started up and it was low and choppy and then the next 4 starts it turned over and immediately died, which its never done before. Now its back to low and choppy consistently. Possible bad IAC?
Wade787b
Sep 29, 2015 01:15 PM
mdtoren
Aug 23, 2015 12:52 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
mdtoren
Aug 16, 2015 05:45 PM
