Spark plugs fouled up repeatedly
Old Jul 11, 2011 | 03:34 AM
roten.ben's Avatar
Hi guys. My spark plugs are repeatedly getting fouled up bad about every 150 miles. And it seems to be all of them, not just certain cylinders or anything. Any idea what the issue could be? I keep having to pull the plugs and clean them, it's getting to be a hassle
Old Jul 11, 2011 | 07:54 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Spark plugs fouled up repeatedly
are they covered in oil or gas? could be a few different things, but that will definitely narrow things down.
Old Jul 11, 2011 | 03:22 PM
roten.ben's Avatar
Oil.
Old Jul 11, 2011 | 03:26 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
most common reason would be bad valve stem seals or worn valve guides
Old Jul 11, 2011 | 05:44 PM
Lumarus's Avatar
Car: 1982 Z28 T-Top Camaro
Engine: Vortec 355
Transmission: T-5 5Speed Manual
Axle/Gears: Stock Limited Slip
I have the same problem, but its not oil its gas.
Old Aug 21, 2011 | 09:43 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
did you find the cause of this? just changed mine today and a few of them for oil covered. what do i need to look for?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 9, 2015 10:01 AM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
