head swap?
Old Jul 12, 2011 | 01:24 PM
brutforceZ28's Avatar
Car: M1A2SEP Tank, project car 83 z28
Engine: 5.0
Transmission: 5 speed
Axle/Gears: what ever came in the car
head swap?
i have a 83 z28 with the 305. will putting 350 heads on make a difference or even worth doing?
Old Jul 12, 2011 | 01:37 PM
Guest
Guest
Posts: n/a
Re: head swap?
Yes, it will make a difference. You'll lose compression.
If you want to go this route, you need the good Vortec heads, and you need to have them milled for compression.
Then you also need to swap intake manifolds to match.
Old Jul 12, 2011 | 01:48 PM
Guest
Guest
Posts: n/a
Re: head swap?
https://www.thirdgen.org/forums/engi...350-heads.html
Engine: 5.0
Re: head swap?
well that sounds like i'm going to spend a little more then i want, think i'll just stick to swapping to the 454
thanks
xkingcodex
Feb 12, 2020 07:43 PM
gta90
Sep 15, 2015 04:00 PM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
