Timing confusion
Old Jul 14, 2011 | 12:39 AM
350tpiirocz's Avatar
Car: 89 Camaro IrocZ
Axle/Gears: 9 Bolt
Timing confusion
Ok so my car dose not want to pass smog for me And today I took it to a shop for an "emission diagnosis" the only problem he found was the timing. He said I had my timing at 20°. How I set my timing was disconnect the timing advance and have the gun pointed at the timing marks. Turned the distributor till 6°. I thought I had it set. The shop guy said I had to jump the connection on the obd1 connection. So I am confused on how I am supposed to set my timing. please help!
Old Jul 14, 2011 | 12:50 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: Timing confusion
the SM states... you do short the ALDL port <> A&B terminal
but it's not needed.... I have timed with & without.... all my TPI cars at least 50 times... made no differnece
it's a must to disconnect the ADV Brown with black stripe.......
Old Jul 14, 2011 | 12:57 AM
Axle/Gears: 9 Bolt
But I mean I did exactly that and he says my timing was at 20° and in my opinion it runs to smooth to be off by 14°.
Old Jul 14, 2011 | 01:01 AM
88gta3508's Avatar
Engine: 231 / 383
someones timing light is off... do you have a adj light??? **** on the back.... or the shop... that timed it... did they disco the adv????
Old Jul 14, 2011 | 01:09 AM
Axle/Gears: 9 Bolt
I used my auto teachers digital timing light And out was set at zero when I set my timing. I have no idea what the shop had I didn't look at there timing light.
Old Jul 14, 2011 | 01:15 AM
88gta3508's Avatar
Engine: 231 / 383
and if you took your teachers light... and set it to 6 Deg does your indicator = 0 TDC
Old Jul 14, 2011 | 01:25 AM
Axle/Gears: 9 Bolt
It should.
RazorN8
Jan 7, 2022 11:44 AM
lt500r55
Sep 1, 2021 01:30 PM
86IROC112
Aug 21, 2015 07:20 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
