Pass Key Decoder Module Location 1989 GTA Trans Am1989 GTA Vats decoder module Locati
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
Re: Pass Key Decoder Module Location 1989 GTA Trans Am1989 GTA Vats decoder module Lo
Are you wanting to disable it or determine the resistance in the chip in the key? I thnk the vats is actually part of the computer program.
Engine: 4++,350 & 305 CIs
If you have to change it youll have fun.. Its between the firewall and bolted to the AC duct work..
I believe I have traced that to be my problem. I have purchased the bypass module from Hawks. It has 4 wires to be connected. One of them has to be connected to one of the wires from the vats module. I have removed 2/3 of the d(*&^%%*)mm dash and havn't located it yet. The wires from the switch are supposed to go to it. When I traced them, they go into a harness and are lost. Thanks for the reply
Is it part of the ECM ? My ECM bad? Followed all the info on here about troubleshooting. Car won't start, won't turn over ect. This is a one owner 22,000 mile TA I have had forever. Always stored inside. About to set it on fire!!!!!!not. It has all the typical symptons of a vats problem, but I can't find it. If it's part of the ECM, how do I test that or just try another ECM? Thanks again
I know when you have a prom burned you can have VATS turned off so I think it's just part of the program.
The VATS module is a seperate module and iirc it's up in the dash behind the radio and maybe a little to the drivers side.
The VATS sends an OK signal to the engine computer so maybe when a chip is burned an always 'OK' can be programmed in to allow the car to start.
Car: '89 Firebird
Engine: 7.0L
The_Phoenix
Feb 4, 2016 07:10 AM
