1989 Camaro w/305 has toxic fumes
Old Jul 15, 2011 | 09:12 AM
Jim Maltba's Avatar
I took the smog pump and catalytic converter off my '89 Camaro that has a 305 engine in it with fuel injection. Research told me there would be no negative effects, but shortly after that my car exhaust became very rich, emitting fumes like a 1950 log truck. The car has 92,000 miles, has been babied all its life and never even ran hard. It has smoked a little for years upon startup because of slightly leaking valve stem seals, but otherwise been problem free. Does anyone have a clue why this is happening or if it is indeed caused by my modifications?
Old Jul 15, 2011 | 11:13 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: 1989 Camaro w/305 has toxic fumes
Removing emissions equipment leads to worse emission out of the tail pipe. Your research was flawed.
Old Jul 15, 2011 | 11:39 AM
Jim Maltba's Avatar
Thanks for the reply Travis. I suspect you are correct, but I have had many cars without a smog pump or a catalytic converter that didn't do this. PLUS there are hundreds of people on just this one web site that have eliminated these items and not had the results I have.
Old Jul 15, 2011 | 01:39 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Did you remove the pipes going to the manifolds too? If so, did you plug the holes?
Old Jul 15, 2011 | 01:41 PM
Jim Maltba's Avatar
Thanks for your reply. Yes & I did plug the holes.
camaro11j
Sep 19, 2018 08:49 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
Derick15
Sep 17, 2016 05:28 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
antares57
Aug 6, 2015 07:47 AM
