Removed cat converter now car smokes
Old Jul 16, 2011 | 09:34 PM
1989 drop top's Avatar
I have a 89 RS 305 TB with only 89,000 miles. I removed the cat converter and now my car smokes like a worn out school bus. All sensors checked out okay. I added a can of sea foam and it got worse. White smoke is rolling out the tail pipes. Please give any suggestions. Thank you!!
Old Jul 17, 2011 | 12:31 AM
affliction1's Avatar
Car: 89 chevy camaro rs
Re: Removed cat converter now car smokes
take video of it
black smoke=burning rich
white=coolant
blueish white=oil
Last edited by affliction1; Jul 17, 2011 at 12:31 AM. Reason: black smoke=burning rich
Old Jul 17, 2011 | 08:48 AM
Its white smoke and the coolant makes since. when I first start it up the tail pipes are very wet. After it warms up they dry out but the smoke fogs up the rear bumper. What's causing it to do it? There is no water in the oil and Im not loosing coolant.
Old Jul 17, 2011 | 01:09 PM
valve seals if its only on start up,what temp are you starting it at?cold?
Old Jul 17, 2011 | 01:26 PM
Its all the time not just at start up. Its not the seals, it never has had a hint of smoke but as soon as I took off the converter BAM! it started. It makes no sense. I'm thinking about just pulling off all the smog junk since the converter is gone. I dont want to since the car has low miles but I'm not about to drive it like it is. Its got to be something simple, I just cant put my finger on it. If any one can help with suggestions I will be forever greatfull! Thanks for looking.
Old Jul 17, 2011 | 06:46 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Hmmm. What could it be.
Old Jul 17, 2011 | 07:27 PM
TreeFiddy, Thanks for you intrest but Im looking for REAL help.
Old Jul 17, 2011 | 07:44 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Cause and effect, just sayin!
Old Jul 18, 2011 | 12:10 AM
take video n post it...i dont have cat either and mine doesnt smoke.well i dont have any smog or ecm crap either so...
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
