Fuel pressure good or bad? VIDEO Inside!
Old Jul 18, 2011 | 02:15 PM
joeyspagz's Avatar
Car: 88 Firebird Trans Am
Engine: 305 tpi
Transmission: 700r4 shift kit
Axle/Gears: Posi
Hey i just tested my fuel pressure again so i made a video so you guys could help me. What do you think normal, Too low?? Should it be moving while revving? http://www.youtube.com/watch?v=SSgoUE5tETo
Old Jul 18, 2011 | 02:25 PM
old z mzn's Avatar
Car: 1992 z-28
Engine: 383 stealthram
Transmission: auto
Axle/Gears: 4.10
Re: Fuel pressure good or bad? VIDEO Inside!
disconnect the vacuum hose to the fuel pressure regulator and check reading. should be 43.5lbs.
Old Jul 18, 2011 | 02:34 PM
joeyspagz's Avatar
Engine: 305 tpi
Axle/Gears: Posi
so will that mean its good?
Old Jul 18, 2011 | 03:11 PM
old z mzn's Avatar
Car: 1992 z-28
Transmission: auto
Axle/Gears: 4.10
yes
Old Jul 18, 2011 | 09:18 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
Looks like 36psi with the vacuum line applied which is normal. And when you turned the car off you actually got 43.5 whichis the reading without vacuum. Buy a Holley adjustable regulator and with the line disconnected adjust to about 48 to 50 psi for a little more power.
Old Jul 18, 2011 | 09:22 PM
joeyspagz's Avatar
Engine: 305 tpi
Axle/Gears: Posi
Thanks burnout88 perfect answer. will this AFPR be good http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Old Aug 6, 2011 | 11:29 PM
burnout88's Avatar
Car: 88 IROC
I recommend this Holley unit. It the best one out there. The BBK unit is really chessy.
http://www.jegs.com/i/Holley/510/512...oductId=746159
specialized
Jun 18, 2022 09:26 AM
Brcharrelson
Aug 26, 2015 07:47 PM
86IROC112
Aug 17, 2015 02:00 PM
R3500
Aug 17, 2015 12:16 PM
Kaweh
Aug 9, 2015 02:54 PM
