adjusting the rockers.
Old Jul 21, 2011 | 12:14 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Hey guys,
I finally have my motor back together and wanted to clear things up on the rocker/calves adjustment. Iv heard of several different ways and was hoping that someone can shed some light I. The best way to do it. Best way iv heard so far was to "do what the book says", get the motor in and adjust from there while its running. It is also with solid liters .
Old Jul 21, 2011 | 12:20 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Re: adjusting the rockers.
Exhaust opening Intake closing EOIC. Rotate the motor by hand or bump the starter over and watch a cylinder. While the exhaust valve is starting to open, adjust the intake. Now watch the intake valve on the same cylinder. When the intake valve is all the way open and just starts to close, adjust the exhaust valve. Repeat on the other cylinders. This is the most acurate way I've found to do this.
Old Jul 21, 2011 | 02:13 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Being that it is brand new, ill bump it over with the starter . Will be a lot easier. And thank you. Any other suggestions are welcome
Old Jul 21, 2011 | 04:55 PM
torque_is_good's Avatar
me, what I've done for years (please don't ask how many ) is to go to the rockers where the valves are not open and get them snug. I then bump the engine and do the rest. Then it's time to start the engine, I back off rockers until they make noise, then tighten until the noise goes away and then another 1/3 to 1/2 turn and I'm done and on to the next one
you don't get oil splatter but can always put a chunk of cardboard if you want
Old Jul 21, 2011 | 05:55 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Yep basically was told to get things close then finalize them while it runs
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
