New here. (92 z28 wont start when hot and hesitation
Old Jul 24, 2011 | 04:45 AM
Jordan92's Avatar
Hey im new here and i need some help with my camaro, Ive got a 92 z28 305 tpi camaro that will not start after it gets hot. It also hesitates under acceleration really bad almost like its the fuel pump but it did the same thing with the fuel pump in it before this one and it was new also.. my dad has owned this car since it was new. I just replaced the fuel pump in it about a week ago along with the starter, fuel filter, plugs,wires, and ignition module. I also checked the timing and the fuel pressure all are good. No plug wires are crossed and no loose grounds. This car has been a problem its whole life. But i still like it and it dont need to set in the garage not running anymore. Also if you unplug one injector" any one" it will accept throttle better. Not sure why though.
Any input is appreciated and im sorry for such the long post. I really would just like to get this car up and running again. It is not drivable at all it hesitates so bad.
Old Jul 24, 2011 | 05:42 AM
Jordan92's Avatar
Re: New here. (92 z28 wont start when hot and hesitation
also to add if you floor the car when it is parked or even ease into the gas slowly it acts as if the car has a two step, or a rev limiter around 3000 rpms and will not go any higher
Old Jul 24, 2011 | 09:15 AM
Sprayed92's Avatar
Car: 92 Formula
Engine: 383 248/256 cam
Transmission: 700r4 3500 stall
Axle/Gears: 9" 3.89 gears detroit locker
Sounds like u might have a bad injector or two. Try ohming them out to see if you have a bad one
Old Jul 24, 2011 | 09:48 PM
92camaroz28ss's Avatar
Car: 92 z28
Engine: fast burn 385
Transmission: t56
how do you ohm an injector? can it be done in the car? i'm practically an idiot with electrical stuff, so a step by step would be awesome!
Old Jul 25, 2011 | 12:21 AM
Lumarus's Avatar
Car: 1982 Z28 T-Top Camaro
Engine: Vortec 355
Transmission: T-5 5Speed Manual
Axle/Gears: Stock Limited Slip
Possiable Cat converter stopping up? i know on my old 97 camaro my converter started to stop up full of carbon build up....so i improvised... took a hammer and beat the livin crap out of it and started up my car and floored it to rev it up to blow out all that crap in it. White clouds of smoke rolled out and cleared up... car didnt hesitate again and drove fine... just went after that and had it replaced... but im not sure about the whole u unplugging an injector and it runnin better thing.. hmmmmmm
1992rs/ss
Jan 31, 2025 05:10 PM
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
