Serpentine belt routing problem
Old Jul 26, 2011 | 08:50 AM
lonesomeloser's Avatar
Car: 1983 Z28
What is wrong here? Why is the belt up against the tensioner?
Old Jul 26, 2011 | 09:16 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Re: Serpentine belt routing problem
The belt should go straight down from the ac pully to the smog pump pully and then from the smog pump pully to the water pump, assuming the tensioner is installed correctly that would put the pully off of the tensioner around the 6 o clock position facing almost straight down from the mounting bolt.
Old Jul 26, 2011 | 09:19 AM
89RsPower!'s Avatar
If you lack a smog pump and or power steering follow this link and it will solve your problems. https://www.thirdgen.org/serpentine
Old Jul 26, 2011 | 09:21 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Look at the end of the link below for routing:
http://sethirdgen.org/serpentine.htm
JamesC
Old Jul 26, 2011 | 09:23 AM
Car: 1983 Z28
I posted a while ago asking if the tensioner was clocked the right way. I guess maybe it's not??? I am not running a smog pump.
Old Jul 26, 2011 | 09:29 AM
JamesC's Avatar
Here's mine.
JamesC
Old Jul 26, 2011 | 09:31 AM
89RsPower!'s Avatar
It's basically impossible to install incorrectly, theres a tab on the back which allows it to only be installed one way, follow the link provided and it will solve your issue, its been done a lot of times.
Old Jul 26, 2011 | 09:43 AM
Car: 1983 Z28
Which tab? The one at 12:00?
Old Jul 26, 2011 | 10:38 AM
JamesC's Avatar
That would appear to be where mine is, though as 89R mentions, there's only a single hole there.
JamesC
Old Jul 27, 2011 | 09:43 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Ha! The 12 o'clock one is correct. Looks like someone was experimenting with extra adjustability. Probably during the smog pump delete.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
mustangdmurder
Aug 21, 2015 07:17 PM
jahblah
Aug 12, 2015 05:54 PM
