valve train combo, dyno sim please?
Old Jul 27, 2011 | 06:57 PM
Camarobuild18's Avatar
Car: 1991 Chevrolet Camaro RS
Engine: 305 TBI, planning on built 400
Axle/Gears: 2.73 stock axles
i have been looking at numerous websites, have not found a dyno sim thats free and easy. Of coarse none of them are lol. I also cant work em with my symbian processor NOKIA 6790. I have also checked out wallace racing calcs, but no luck on precision. But i have a very intresting combo, here are specs, if you could help me please, here they are. First off my wants. Power band 1500-6100 rpms?, Cubes 400 sbc personally preferred. Also what i have on hand. Cam intrests, are : hyd roller .525/525 (max lift bc of valve guides) advertise duration 295/301, valve lobe seperation 110 degrees. LSA?? Any suggestions for cam pick let me know. intake runners 175 cc, 50cc exh. 1.94 int. 1.50 exh. Summits Vortec fast burn heads 67cc combustion chamber, Holley 750 (dual feed) cfm on a air gap intake, 5.7 inch rods, origanals were fried. 18cc dish pistons from kieth black. If you can sim this Please do! Thank ya, Alex.
Old Jul 27, 2011 | 07:23 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: valve train combo, dyno sim please?
Try www.camquest.com it's CompCams dyno sim
Old Jul 27, 2011 | 08:02 PM
i have tryed it with no luck, wish i had a computer, all i have is this nokia phone. Wish i could also unlock its every potential but youd have to be a rocket scientist thanks man
Old Jul 27, 2011 | 08:07 PM
Post some cam specs and some head specs and maybe someone will volunteer to donate you the fruits of what they spent their hard-earned money paying some hard-working and intelligent programmer with an expensive education AND A COMPUTER his daily bread to create?
Old Jul 27, 2011 | 08:12 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
You dont have to be a rocket scientist, but owning a computer, or even a cheap netbook would be a good start if you want to do anything on the net.
Old Jul 27, 2011 | 09:16 PM
Engine: 383 SBC
Go to your local library. Most have free internet and computers to use. Problem solved.
What is the purpose of the motor?
Going to run a converter?
Those look like kinda small heads for a 400, but I guess it'll be more torquey than hp.
Are you aware 350 blocks and 400 blocks are different?
Ran quick numbers for you:
397 hp peak @ 5000
453 tq peak @ 4000
avg 237 hp
avg 307 tq
That's with 9.5:1 and 280HR cam (.525 .525 lifts 224 224 duration 2000-5500 powerband)
You're not going to see much in the high end of the rpm scales with small heads on a big motor. The larger bore size has to help to some degree but still it's a 175cc runner.
Old Jul 27, 2011 | 10:13 PM
397 hp peak @ 5000
453 tq peak @ 4000
avg 237 hp
avg 307 tq
thanks for your comments, there just budget heads idea for right now but later on down the road ill be updating them to the better heads. Ill grab a set e-tecs Yea i know there very different, 350 and 400 different bores and different stroke, not to mention the steam holes needed for the heads to work which i have done alot of research on and they say its quite simple can drill em with hand drills. This is my dad and I's project so yea its family hobby for the first time LOL. This is what we love to see in all sorts of cars just some real american muscle. Know its like later in the gas days but we still love them sb chevy V8s. But were not letting this economy get us down and stuff still dreaming of horsepower and cubes of our own.
And i dk i just forgot all about the library, ill go there look up some other things too. Edit: i also forgot to answer your qeustion yes were planning on a stahl convertor some where around power band, and im also looking at pinion and ring geat ratios, 3.73:1. I have some time before i build this sbc 400. Have alot of curiousity running through me. Again thanks everyone
"i learned alot by asking all sorts of questions, mainly about things people dont ask about. So yes, it is healthy to be curious."- Albert Einstein
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
Nick McCardle
Sep 10, 2015 08:36 PM
