Need help with 85 camaro that is barely running
Old Jul 27, 2011 | 12:19 PM
Footy's Avatar
Car: 85 Chevrolet Camaro IROC-Z
Engine: LB9
Hello, so I'm having some problems with my 85 camaro. I was driving home from my girlfriends last night and as exited the highway and gave it gas it started running so rough that I had to basically crawl home. So I go out this morning to take a look at it and it is very hard to start and you have give it a lot of gas for it to fire. When i finally got it started, the whole car is shaking like crazy and it is super rough and has no power. It also drops down to about 100 RPMs sometimes and dies. I'm 17 and I have some knowledge with cars and I would really like to fix this myself because firstly, the car won't even make it to a shop, and secondly, i can't afford it. It has the 305. Anyway this is the first time I've posted and i would really appreciate any help. Thank you.
-Andrew
Old Jul 27, 2011 | 12:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Need help with 85 camaro that is barely running
Strange. Sounds like you may be misfiring on a cylinder. Where to start? Is this really a 1985 LB9, ie a 305 TPI engine? How many kms? Smoke when you get it running? Check your oil and glycol, any weirdness?
- Pull spark plugs, and inspect. Lay them out on a white sheet of papertowel, in order. You can post a picture of the spark plugs if it's not readily apparent what you're looking at/for. That may answer your question right there.
- If not, pull your valve covers, grab each rocker arm and wiggle. Most of them will be loose, a couple will be tight. That's normal. If any valve springs are broken, valves dropped, rocker studs pulled up, etc - problem.
I'd start with those.
Old Jul 27, 2011 | 01:29 PM
Footy's Avatar
Engine: LB9
Thank you for the reply. Yes it is a 305 TPI and it has 205,000 KMs. There is no smoke and the oil is pretty fresh, the coolant is a little dirty though. I'll have to work on getting the spark plugs out because my headers are in the way and I don't have too many tools due to my parents splitting, that is changing though I'll let you know when i get them out
Old Jul 27, 2011 | 01:33 PM
Footy's Avatar
Engine: LB9
I just did the paperclip thing and it's throwing codes 13, 32 and 43.
Old Jul 27, 2011 | 03:35 PM
Footy's Avatar
Engine: LB9
I'm really sorry for wasting your time man, it seems i ran out of gas I'm such a moron. My gauge must not be working, but thank you for you help
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Vintageracer
Jan 10, 2020 05:33 PM
pimp2303
Jul 27, 2017 02:03 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
