air conditioning
Old Aug 3, 2011 | 06:49 PM
built's Avatar
Car: 82 TA
air conditioning
Today I got my air condition working , it hasn't worked in years, put oil,stop leak and refrigerant in it and it was cooling great, compressor kicked on and was cycling normal but when i shut off the car i could hear a big leak from behind the compressor and it looks like it is coming from a round thing on the back like maybe it's a pressure relief valve , Is that what it is?
what can I do to stop it from leaking, will it reset itself?
a little while later it was back to blowing hot air again
Old Aug 3, 2011 | 07:09 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: air conditioning
Can you take a pic of the area on the compressor where it's leaking?
Old Aug 4, 2011 | 01:29 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
About the only thing you can do is replace the compressor and recharge everything.
Old Aug 4, 2011 | 03:33 PM
MY87LT's Avatar
Car: 1987 Camaro LT
If it has a snap ring that holds it in, you need to get a replacement O ring and new snap ring. I think I know what he is talking about.
Old Aug 4, 2011 | 07:22 PM
built's Avatar
Car: 82 TA
I can't get a picture because of all the lines ,hoses and brackets in the way.
I can't even see it very good so I can't tell if it has a snap ring or not.
I can't spend a lot of money for a new compressor so If it doesn't reset it self to take a charge again I will just have to keep driving with no air conditioning.
I'm not totally sure how to even remove the compressor without hurting the lines etc.or special tools I might need.
Hate being poor !
Old Aug 4, 2011 | 07:38 PM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
as far as i can tell there are no special tools needed to remove it , my friend just got a compressor from a junk yard for 35 bucks . They came on alot of cars not just f body's .good luck.
Old Aug 8, 2011 | 12:09 AM
built's Avatar
Car: 82 TA
I just need to make it work for this summer now, i'm thinking of selling the car and getting something newer for a daily driver this one isn't working out for that.
How about this, can I ******* it and get by this summer by jb welding the leaking valve and be very carefull to keep the pressure when filling it to close to 50 psi and be good for now ?
Old Aug 8, 2011 | 01:54 PM
jtsk's Avatar
I don't know about that. I imagine the JB won't hold.
Vintageracer
Jan 10, 2020 05:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
jackhammer
Aug 15, 2015 10:04 PM
