Need Help Failed Inspection High HC PPM at idle
Old Aug 11, 2011 | 08:10 AM
xsvtank's Avatar
Hey guys im new to the forums my name is Frank. i just got a 88 firebird formula with 75k miles for a steal.
So basically i failed the inspection my HC at idle was 320 its meant to be under 220 according to the sheet they gave me.
The car does have a cat and passed all the other tests.
The car was sitting for about 12 years i know the owner put wired and a new fuel pump on the car, it also had old gas sitting in it but i had already burned through about 2 full tanks of gas. im thinking i may just need new plugs im not sure if they were changed so i will take a look today to see what condition they are in. Is there anything else that i should look at?
Thanks 3rd gen guys,
Frank
Old Aug 11, 2011 | 10:43 AM
Dougs91's Avatar
Car: 91 Camaro
Axle/Gears: 3.23 limited slip from 91 Z28
Re: Need Help Failed Inspection High HC PPM at idle
I would check the O2 sensor and air filter. The plugs are probably fine unless it has a cylider not firing.
Old Aug 13, 2011 | 11:28 AM
xsvtank's Avatar
anyone else?
GTAman
Mar 15, 2019 11:40 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
GTAman
Sep 21, 2015 09:57 AM
db057
Sep 4, 2015 07:57 AM
