should the IAC sound like this?
Old Aug 11, 2011 | 06:06 PM
coptzer's Avatar
Car: 1986 IROC-Z
Engine: LS1-ish
Transmission: T56 stage II
Axle/Gears: S60 4:10's
So i was checking a code on my car, and when I inserted the jumper in the ALDL, my IAC was making an awful clicking sound. Does this mean it was bad? I have been having alot of problems with my car not starting when hot. I have done alot of research on here and figured it is probaly my ICM, but would a faulty IAC cause this?
I figured this sound couldn't be normal, so I took the IAC out and attempted to clean it. Well I know it is bad now, cause when I tried to get it apart it fell apart in my hand. I am just curious if this was normal sound, I don't remember hearing it before.
OH well now it is off to get a new one.
Thanks!
Old Aug 11, 2011 | 06:22 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: should the IAC sound like this?
The only time you'll hear an IAC is after putting it back in. You'll hear it go "thunk" once as it resets itself. Otherwise, no noise.
Old Aug 11, 2011 | 06:31 PM
coptzer's Avatar
Car: 1986 IROC-Z
Engine: LS1-ish
Yeah, I was thinking it wasn't normal. Guess that's why it fell apart when I tried to clean it.
db057
Jan 10, 2020 08:55 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Fred SS
Oct 12, 2015 11:27 AM
steimel94
Sep 20, 2015 12:46 PM
greenyone
Sep 2, 2015 03:39 PM
