Looking for cam for low budget 305 rebuild...
Old Aug 11, 2011 | 01:46 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Looking for a low priced flat tappet cam for a low budget rebuild for my 305 which will be running a factory tpi setup with stock prom. Looking for something reasonably priced that will be able to pass emissions testing and run decent in a otherwise factory setup. I'd prefer something a bit more aggressive than factory that would fit the above criteria. I'm mainly considering this as a back up plan, I'd prefer to find a low priced used LT1 roller cam but I would also need all of the factory roller components with it as well (I used the origional lifters, spider tray, etc when building a 350)
Old Aug 11, 2011 | 03:27 PM
Guest
Guest
Posts: n/a
Re: Looking for cam for low budget 305 rebuild...
I stuck a Comp 12-388-4 in my '86 LB9, it seemed the perfect match. No regrets on that, at all.
It gained me a noticeable improvement in mid-range torque. I couldn't tune my TPI, I didn't have the chip burning hardware or software, or I would have tried a 212/218-110 444/454
Old Aug 11, 2011 | 04:32 PM
92firebird 305's Avatar
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
get a lt1 cam with new vavle springs and your good to go and change your timing chain when you do it to
Old Aug 11, 2011 | 07:39 PM
Guest
Guest
Posts: n/a
That's real bright. Did you even read the OP? The LT1 cam is virtually the same specs as the early LB9 cam, but the LT1 cams have slightly more lift, and the LT1 cams are for '87-up blocks and roller lifters.
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
camaro71633
Sep 1, 2015 10:24 AM
hokis
Aug 9, 2015 03:57 PM
