Help! Car wont start
Old Aug 12, 2011 | 11:08 PM
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Got a 305 TPI. Has spark and fuel. Will turn over and keep spinnin but wont start. Any ideas on what it is??? Plz help me My daily driver. Need it fixed ASAP
Old Aug 13, 2011 | 12:51 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Help! Car wont start
Spark isn't enough it must be on time. if you mean by "fuel" that you have fuel pressure, the injectors must open to release the fuel.
Don't make it a mystery check each of the following, one is missing:
air is a given
quality spark
fuel actually getting into the cylinders
correct timing
minimum 80 psi cylinder pressure
Old Aug 13, 2011 | 10:58 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
well i dont know what the fuel pressure is. It has fuel pressure but i dont know how much it is, gettin a tool to check. There is a fittin on the fuel rail to check, what is the pressure supposed to be? I've heard between 35 and 45 PSI, is that correct? I have new spark plugs, wires, fuel filter and air filter. Will check injectors today
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
