88 GTA Fuel pump stopped working??
Old Aug 13, 2011 | 08:33 PM
crazylarry's Avatar
Car: 88 GTA,87 GTA, 71 Karmann Ghi
Engine: 5.7 tpi /5.0 tpi
Transmission: 700r4 modified
Axle/Gears: borg warner 3.27
I would appreciate any ideas you may come up with...
Past history... '88 GTA 350 TPI new battery, alternator, timing chain etc.
Mint condition Sunday driver owned for 10+ years no starting issues 150,000 kms ( 100,000 miles)
Last year oil sender changed ...fuel pump would not shut off.
Ok, today I started the car, no problem but after about 30 seconds it lost power & stalled..would not restart... fuel pump not running.
I checked the 20a fuse by battery...good
only power at the orange wire on relay, with or without key on.
I know the fuel pump is original but would like to be sure it was the problem before dropping the tank.
Any ideas for my next move?
Thanks in advance for your suggestions....Larry
Old Aug 13, 2011 | 08:37 PM
Mitch91Z28's Avatar
Car: 1991 Vert Z28
Engine: 305... LS1 waiting to drop in
Transmission: 700-R4... soon 4L60E
Axle/Gears: 3.08 posi nine bolt
Re: 88 GTA Fuel pump stopped working??
did you try to jump the relay and see if the pump spins up?
my pump went out today too
Old Aug 13, 2011 | 08:47 PM
crazylarry's Avatar
Hi
I have been reading up on that & plan to check it out in the morning.
I guess I just supply 12v to the red wire...if I have one?
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
beachrodder
Aug 25, 2015 08:05 AM
justin57
Aug 20, 2015 07:05 PM
Newguy91rs
Aug 7, 2015 09:51 PM
