Is This Fuel Pressure Common on Start Up?
Old Aug 16, 2011 | 10:40 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Okay guys. I have a hard time getting the IROC to start immediately. So I recorded the pressure at prime, and during start up. So is this a good pressure givin the situation?
http://www.youtube.com/watch?v=E_BbCaJ43w0
Old Aug 19, 2011 | 01:24 AM
Re: Is This Fuel Pressure Common on Start Up?
bump
Old Aug 19, 2011 | 01:43 AM
skibum2100's Avatar
Car: 1988 GTA
Engine: 5.7 TPI w/ Bosch III's
Axle/Gears: 3.27 Borg Warner 9 bolt
I believe your fuel pressure is falling too fast after engine stop. I wonder if you have replaced your fuel pressure regulator diaphragm. A torn / leaky diaphragm can result in a pressure drop like that.
Maybe the 9th injector is leaking as well. Unless you replaced it at the same time as the other injectors.
Hope this helps.
Old Aug 19, 2011 | 08:32 AM
Boulder CO! I used to live in Colo Sprgs, then in Greeley. I miss living there. My FPR diaphram is about 2 years old. Should still be good. All my other injectors are 1 year old Bosch 3's. I'm gonna pull out the 9th injector and prime the FP to see if there is any leakage. Is it possible to pull the 9th injector with the runners in place?
Old Aug 20, 2011 | 12:57 PM
skibum2100's Avatar
Car: 1988 GTA
Yes, you can easily and quickly remove the 9th injector. Loosen the nut holding the line to the back of the fuel rail, then remove the bolt holding the injector. Now rotate the injector and line upwards, pivoting at the fuel rail, and it should clear the runners so you can test it.
Hope this helps.
And...yea, I like Colorado too. It doesn't better than 300 sunny days every year to enjoy my 3rd gen.
Old Aug 20, 2011 | 01:38 PM
Sweet. Thanks for the advice skibum2100.
Old Aug 29, 2011 | 01:01 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Any luck fixing your issue? I agree to change the fuel regulator diaphragm.These replacement ones dont seem to last like the original gm ones did and I had this exact same issue.Is your afpr adjustable?
Old Aug 29, 2011 | 01:04 AM
No man. Mine is not adjustable. I haven't had time due to being a full time student and also because I just had surgery.
Old Aug 29, 2011 | 01:08 AM
Engine: 2005 LQ4
Axle/Gears: 3:54
Thats sucks man,sorry to hear that.Im sure you will get it fixed up in no time.its a common issue with the diaphragms leaking and causing hard starts and high rpm stuttering.good luck.
Old Aug 29, 2011 | 01:11 AM
thanks man.. ill keep ya posted.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
killer777
Aug 8, 2015 02:47 PM
