91 Z28 305 TPI 5speed
Old Aug 17, 2011 | 12:52 PM
Z5speed's Avatar
Car: 91 Camaro Z28
Transmission: 5speed
I recently bought a 91 Z28 and shes bonestock. I had a few things i was wondeing about like the smog stuff thats on there. What all is involved in taking it off, also will the check engine light be on? What is a good rpm range at idle warmed up after driving about 15-20 minutes. I was looking at putting the Eibach Sportline lowering springs on her, is there anything that i should or have to change before then? Any info will help out a lot,Thanks!
Last edited by Z5speed; Aug 17, 2011 at 04:22 PM. Reason: had one more question to add.
Old Aug 17, 2011 | 06:26 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 91 Z28 305 TPI 5speed
www.thirdgen.org/serpentine
I'd do shocks/struts with springs, as well as ball joints, tie rod ends, idler arm, sway bar bushings, and end links.
Welcome to TGO - all answers are here - very beneficial to use the function - 99.99% of all questions have been answered already, saves you and us time.
Old Aug 18, 2011 | 08:21 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Removing smog equipment will do nothing for performance. If you do decide to, it would be better to have "air" removed in the chip also.
Old Aug 19, 2011 | 11:56 AM
Z5speed's Avatar
Car: 91 Camaro Z28
Oh really? I was told if you take it all off it will help out mostly cause your taking one of the pullies off of crank and was good for +10-15hp. Also whats the "air" removed in the chip your talking about? Is it like the hypertech chip? Cause thats one of the little bolt-ons I was going to do. I dont want to go to crazy with her cause she is alllllll original and i just love that haha I just want a fun street car!
Old Aug 19, 2011 | 01:01 PM
ninetyone's Avatar
Axle/Gears: 3:42
You won't really see any gains that way,maybe if you go with underdrive pulleys,then you may gain 5hp. If anything,and you will run into charging problems with underdrive pulleys if you do the alternator pulley. Hypertech cannot change any of the emission settings . So there is your answer to "air removal" What i was referring to is a custom chip you would make or have some one else burn for you.Then you could have "air " removed from the chip.I would not bother with a hypertech. I picked up 20 hp going back to my stock chip.
Old Aug 19, 2011 | 01:02 PM
ninetyone's Avatar
Axle/Gears: 3:42
Keep the smog equipment
jaridjohn
Jul 8, 2024 03:49 PM
gta90
Sep 15, 2015 04:00 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
