Help Changing Spark Plugs 91 Camaro Z28
Old Aug 19, 2011 | 01:11 PM
Bighawk's Avatar
Car: 91 Camaro Z28
Engine: 5.7L
Hey. I need to replace all the spark plugs in my car. It's a 91 Camaro Z28. It has a 5.7L in it. Just wondering what tools will i need? How far to gap? How much to turn the screws? And any other helpful information or advice? Maybe a guide i can look at?
Old Aug 19, 2011 | 05:11 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Help Changing Spark Plugs 91 Camaro Z28
Depends,do you have headers? If not should be fairly easy. Now the plugs in the back,especially on the passenger side may require you to get them from under the car.
Old Aug 19, 2011 | 05:38 PM
shortyskater's Avatar
Car: 1987 Chevy Camaro Iroc-Z
Engine: just an empty hole. LS1 coming soon
Transmission: nothing there either. T-56 soon!
Axle/Gears: soon Moser 9 bolt
All you need is a spark plug socket, few exentions, maybe a universal joint, and rachet. They can be a pain to change and take some time. Like ninety said, if you can't get them from the top go from the bottom. I changed all mine from the top and I have the stock manifolds on with A.I.R. still connected. They sucked none the less but I managed. When you pick the plugs up ask the parts people for the gap. I forget off hand what it is.
Old Aug 19, 2011 | 06:33 PM
Bighawk's Avatar
Car: 91 Camaro Z28
Engine: 5.7L
ok thanks. and its stock manifolds. is there a way to tell which one needs to be replaced so i dont have to change all of them? its missing i just dont know which one.
Old Aug 19, 2011 | 07:23 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
The plugs nearest to the firewall 1 & 3 can be reached from underneath. I like using a fine click universal ratchet.
Old Aug 19, 2011 | 07:25 PM
ninetyone's Avatar
Axle/Gears: 3:42
stock gap is .035
Old Aug 19, 2011 | 07:26 PM
ninetyone's Avatar
Axle/Gears: 3:42
don't u mean 7 and 8?
Old Aug 19, 2011 | 07:27 PM
ninetyone's Avatar
Axle/Gears: 3:42
that could be a bad plug wire.
Old Aug 19, 2011 | 07:33 PM
Yes I did mean 7 & 8. Long day, and I am slipping a little.
Old Aug 20, 2011 | 12:00 AM
Bighawk's Avatar
Car: 91 Camaro Z28
Engine: 5.7L
so do i need to replace all of them or is there a way to find out which one is bad?
Old Aug 20, 2011 | 01:50 AM
I would change all plugs, all wires. Chances if one of any of these is bad, then the rest are not far behind.
Old Aug 20, 2011 | 02:00 AM
notoriouscamaro's Avatar
Car: 92 RS 5 speed
Engine: 5.0L TBI
Axle/Gears: 9 bolt rear
I agree!! Also, make sure you get a spark plug socket that's padded on the inside! It prevents you from cracking the spark plug. I bought mine at sears (craftsman should be fine). I'm pretty sure its 5/8" size with a 3/8" drive. It also has a hex end which you can use a box end wrench which is really useful!
And like another user said, you NEED a u-joint! Make sure you use anti-seize on the threads of the new spark plugs.
Shouldnt take that long..It took me an afternoon in the driveway. Having the right tools helps!
Old Aug 20, 2011 | 02:01 AM
Car: 92 RS 5 speed
Engine: 5.0L TBI
Also, buy yourself a haynes manual. It tells you the gap info and torque specs for everything on the car. The instructions helps so much too on hard jobs.
Old Aug 20, 2011 | 08:50 AM
Bighawk's Avatar
Car: 91 Camaro Z28
Engine: 5.7L
well i just had my engine rebuilt and new spark plugs at the beginning of the year. Thats why i didnt think they were going bad. Is there a way to tell if its actually missing or do i just take the guys advice? A mechanic down the road from my house said he heard it missing as i drove by then listened again as i revved it. He said definately a miss. I just dont know why it mess up so soon. I understand how to replace everything now. I just want to make sure its necessary before i do?
Old Aug 20, 2011 | 10:43 AM
Seven_MPG's Avatar
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
Whenever I change the plugs I find it easier to snap them off with a few taps,then put a socket on them.Helps a tad because you can use a short socket instead of a deepwell.Just be carefull not to cut yourself.
Old Aug 20, 2011 | 11:14 AM
ninetyone's Avatar
Axle/Gears: 3:42
of course,why not. the wires are under $20
Old Aug 20, 2011 | 03:55 PM
Bighawk's Avatar
Car: 91 Camaro Z28
Engine: 5.7L
ok thanks for all the advice. i replaced them all with no problems. thanks again
1992 Trans Am
May 10, 2023 07:19 PM
apo_bailon15
Mar 28, 2016 05:20 AM
db057
Aug 22, 2015 08:17 PM
92camaroJoe
Aug 13, 2015 06:07 AM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
