Cam Change ?
Car: 86 Camaro Coupe
Engine: currently building a 355
Transmission: unsure what it will end up with
Axle/Gears: 10 Bolt 2.73
Cam Change ?
I am new at engine performance mods and was wondering if a 5.7l .414/.428 Lift camshaft will work in my 88 Iroc 5.0L TPI?? If it will what will that do to the engine as per performance??
Engine: 4++,350 & 305 CIs
Re: Cam Change ?
Not enuff to make the swap worth it.. What are your goals with the car??
Re: Cam Change ?
I want to go from stock numbers of 195hp/295tq to 300hp/400tq.... I am going to use this car as a donor for my v6 camaro and plan on doing some engine work in btw car to car... any ideas to help?
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
Re: Cam Change ?
I would do a compression check before modding the motor.
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Cam Change ?
460/460 lift is the max to go with stock springs on the stock heads.
220/220 @.50 is about the max duration you should go without chip tuning. Take a look at the largest Crane Compucam, that will give you an idea of how large a cam you can go. That is, without changing anything else on the motor.
