thoughts on my 454's performance
Old Aug 23, 2011 | 10:20 PM
niceroc's Avatar
Car: 87 iroc
Engine: 454 .030 over
Transmission: th-350
Axle/Gears: 9 bolt
i have a 454 that i took to the track for the first time last week. she is in a 3500 lb camaro. here are some of the specs:
1050 dominator
team g single plane intake
781 large oval heads w/ 2.25"/1.88" valves
13:1 compression
262/270 @ .050" dur and .637/.635 lift solid flat tappet
1 7/8" hooker headers and dual 3" thrush welded mufflers
3800 stall with a th350
she ran a 12.02 at 117 mph with a 1.81 60'
she had a afr of 11.8-12.0 on the run with 87 front and 88 rear jets
34 degrees timing on vp110
shifted at about 6800
my only problem is i thought she would be making more power, do you think i left much power on the table with the timing and afr so low? or do i need a smaller carb/ bigger headers?
Any thoughts would be appreciated
Old Aug 23, 2011 | 10:41 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: thoughts on my 454's performance
Rear gears? Tire compound & size? Suspension mods?
This may help the gurus out there help you..
That's very close to the build I want to do!! I'll be following this!
Good luck!!
Old Aug 23, 2011 | 10:49 PM
niceroc's Avatar
Car: 87 iroc
Axle/Gears: 9 bolt
I'm still on the 3.45 9 bolt, running et streets thus being the reason I didn't want to launch it too hard. The car has stock suspension with spohn LCA's
Old Aug 23, 2011 | 11:11 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
AFR isn't bad. Slightly rich but still in a good range. I wouldn't recommend going more than 12.7.
Bump up the timing. 34 is a little low. Try 36-38. Changing the timing will change the AFR.
If you're shifting the TH350 at 6800, what rpm are you crossing the finish line at?
I did that with only a 383 10+ years ago. Something in your combination of parts isn't working well together. There's no reason you shouldn't have a 10 second timeslip.
Old Aug 25, 2011 | 03:56 PM
EvilCartman's Avatar
Car: '82 Z28
Something is off, that thing should be doing a lot better than it is. Don't need bigger headers, guys go 10's using 1 3/4". Bump the timing up and see what happens.
Old Aug 25, 2011 | 04:34 PM
grumpyvette's Avatar
make only one change at a time and take notes,
that combo should easily go noticeably faster, but Id get the a/f ratio closer to 12.7:1 and make the timing curve look like this as a first step, and advance the timing slowly
http://forum.grumpysperformance.com/...php?f=55&t=109
http://forum.grumpysperformance.com/...php?f=70&t=202
http://forum.grumpysperformance.com/...hp?f=70&t=2798
Jorlain
Oct 8, 2015 01:57 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheExaminer
Sep 6, 2015 11:40 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
z28guy134
Sep 1, 2015 11:50 PM
