Did a lot of work - want to know where the oil pressure should be.
Old Aug 26, 2011 | 10:24 PM
Mr Froman's Avatar
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
It's about 30 cold, goes down to about 15 when the coolant is 198*.
I have had the heads machined+valves done, replaced my leaking oil pressure switch. It's running Pennzoil 5w-30 SYN. right now.
I'm not sure where it should be. When I got the car back in 07, the oil pressure was all over the place.
Old Aug 26, 2011 | 11:58 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Did a lot of work - want to know where the oil pressure should be.
15-ish at idle hot sounds ok. Then 10-ish more for each 1000-ish rpm.
If pressure reading is all over the place, replace the sender first, and/or try another gauge, before freaking out.
Old Aug 27, 2011 | 12:09 AM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
15 hot and 30 cold is a little low, not the worst though. could be the sender as previously mentioned, could be the gauge, could be the oil pump or in worst case, its the main bearings starting to wear
or low on oil or need an oil change- this is obvious and probebly doesnt apply
Old Aug 27, 2011 | 06:54 AM
Mr Froman's Avatar
Sender is new. Oil level is fine. I'll check it with an actual gauge, similar to one used for a compression test.
Old Aug 27, 2011 | 10:43 AM
aremy10's Avatar
Car: 91 firebird
Axle/Gears: stock
best range would be in between 35-45. varies with rpm, but 15 is low
Old Aug 27, 2011 | 12:02 PM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
The stock dash gauge is not a precision instrument - so long as the pointer is off the peg at idle, and goes up with rpm, is as good an indication as it's going to give. More an indicator of oil pressure behaviour, rather than absolute psi.
My pointer will typically read lower hot vs cold, as the oil gets thinner and easier to pump.
TheExaminer
Aug 26, 2015 04:59 PM
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 11, 2015 03:17 PM
