Brake lights and gauge lights not working.
Ok, I did some reading through similar threads but I need some more info before I get to troubleshoot my problem.
1. My camaro has separate blinker lights than the brake lights (aren't all camaros like that?). In this case does the turn signal switch have any role in controlling the brake lights? Can it be causing their failure?
2. The gauge lights don't work. I read this is intentional to tell you you don't have brake lights. Can this also point me to where the problem could be?
3. Hazards work properly, turn signals don't. (I don't remember which one) lights up, but doesn't blink when headlights are on and the other one blinks, but also dims the left headlight.
4.Have I understood right that a light blue line goes from the brake switch to brake light sockets, feeding them 12v?
Thank you!
Thank you!
